SOS/8-speed swap
Fordfarmer
I had mentioned here some time ago that a friend's 5000 SOS had a broken shift cable, and not being able to find a replacement, he had bought a tired gas/8-speed as a donor for a swap. Things happened, and the project got put on hold until last week. I have both split now. SOS has a nearly perfect input shaft, while the 8-speed's PTO input shaft and hub are worn bad enough they should be replaced.
