Mounting a Fork-lift Mask On A Ford 6000
KCTractors
Location
Central Wi
I want to mount a fork-lift mask on the 3pt of a Ford 6000. I need the 3pt to lift the whole mast. I need one ( two-way)for the hydraulic tilt on the top-link and one single for the hydraulic cylinder to lift the telescoping mask. Anyone have an idea of how to do it.
(quoted from post at 19:02:27 04/26/19) I want to mount a fork-lift mask on the 3pt of a Ford 6000. I need the 3pt to lift the whole mast. I need one ( two-way)for the hydraulic tilt on the top-link and one single for the hydraulic cylinder to lift the telescoping mask. Anyone have an idea of how to do it.
Are you looking for mounting suggestions or hydraulic pipeing and valve suggestions
My 9000 has valves that stack. You install and supply one and you can add as many as you want on top of or beside it.
6000 offered two remote valves sitting side by side. I'll try to send a pic of mine. 6000 uses a closed hyd. system so plumbing will be simple. If you need info on plumbing let me know after you get your second valve. The valve will have to be for a closed system and some valves have an option to convert from an open system to a closed system.
Jim in Alabama
Here's a couple of pics on dual remote valves on a 6000.
Oil volume capacity to supply the mast cylinder and pump flow after depleting the accumulator charge will be challenges to your project.
Maybe, I would be better off putting a PTO hydraulic pump on along with a reservoir and 4-spool valve. I want to put a Schwartz loader on the front to.
