lastcowboy32
I got my left brake pedal off. I let the shaft clamp soak for a couple of days with penetrating oil, then sharpened my beater wood chisel and tapped it between the pedal and the inside washer. That little bit of wedge action got her moving.
The point of this was to get at the teeth on the parking brake lock, in order to renew them. I've had this tractor for three years, and the parking brake has never held well.
Learned a couple of things...
A. The lock is riveted to the pedal, and if you really want to sharpen up the teeth, you'll have to drill out the end of the rivets and take it off.
B. I thought that I could replace the rivets with bolts. No dice. They aren't 3/8"...they aren't 5/16"...they aren't 10mm.
As nearly as I can tell, by testing with drill bit shanks, you would need a 21/64" or 11/32" to match the tightness of the rivet.
C. You can nicely sharpen the teeth by flipping your angle grinder on it's back, locking it on (with the speed control set on the lowest setting) and just free hand them with a thin cutoff wheel.
D. I had enough of the rivets left to re-use them. I just welded them in place. I don't think I'll have to worry about removing them 50 years from now...
