Ford 3000 power steering swap
fbomb46
New User
I have a 1965 3000 diesel with manual steering. I'd like to swap the power steering components from an early 70's donor 3000 with a gasoline engine. Is this a direct swap or do I need to find a 65-68 model? Thanks in advance!
In 69 or 70 Ford changed the mount location of the radius rods from the center axle to the drops.
That 70 steering sector and linkage will work but you'll need the axle drops as well in order to reconnect the newer radius arms.
