Ford 3000 Fuel Gauge
dustcover
New User
The wiring harness does not supply a wire for the fuel gauge, it says wire needs to be supplied, Question,where do I
hook the wires from the fuel sender. There are two contacts on the sender unit. Thanks,
(quoted from post at 14:36:56 04/18/19) The wiring harness does not supply a wire for the fuel gauge, it says wire needs to be supplied, Question,where do I
Yes, the wire from the gauge to the sender is so short that it is not part of the main wire harness. If your sender has two terminals check the resistance between each of them and ground. If one of them is zero resistance to ground then connect the wire from the gauge to the other one. If neither is zero resistance to ground, then you should be able to connect the wire from the gauge to either one of them, and then add another wire from the other terminal on the sender to ground.
To: Sean and JMOR, Thanks so much for the reply to my question regarding the fuel tank issue. Now my challenge is transferring the instrument cluster to a new wiring harness. I will try and print out the schematic that you sent me. Thanks
