Order Ford 601 Parts Online
601 tranny
jrmo
04-22-1999 08:36:34
Do these tractors have select-o-matic? If so how can you tell? Is it labeled some way? I have no experience with these tractors.
Thanks
Dave Mischler
04-22-1999 10:04:11
 Re: 601 tranny in reply to jrmo, 04-22-1999 08:36:34
The 601 was available with the Select-O-Speed transmission. The most obvious difference with this transmission is that the shifter is bolted to the dash rather than on the floor (actually, the transmission cover) like the 4 & 5 speed transmissions. Also, it has 10 forward speeds and 2 reverse speeds, plus neutral and park. There is a cable (like a brake cable) that transfers the shifter position info to the transmission itself.
RK Smith
04-22-1999 10:02:47
selectomatic was an automatic trans. I'm sure someone else will have another opinion - but I'm also sure that if you buy one with a selectomatic, you'll probably regret it. Never heard anything good said about it. Take it back, one guy told me it was the happiest day he could remember - the day he sold it.
RICK
04-22-1999 16:45:10
 Re: Re: 601 tranny in reply to RK Smith, 04-22-1999 10:02:47
It's S-O-S Select-O-Speed. Opinions very greatly on performance.With a little experience you can tell the difference at 100 yards.
