radara4077
Had an issue with the lift on my 841S. Wouldn't raise at all. It sat all winter (inside), and now I finally got it to the mechanic to repair. The Cam Follower Pin was all but gone, so I got a new one and he got it installed. A few evenings later, I came to help him, and we followed the I&T manual's guidelines for adjusting the linkages (one was off by over a 1/2 inch). Once we got the top cover back on, the rear arms would lift just fine, but appeared to not "go all the way down" if that makes sense. They would travel most of the way, then encounter what felt like (from standing on the lift arms) resistance that built as it lowered (across maybe 6 inches of travel at the end of the lift arms) until they came to a stop. Pushing slightly down on the draft control lever would send the arms lower, and shifting totally into draft control would cause the arms to move on down until the upper linkage touched the rear axle.
What could be causing this? I have apparently ran the tractor for years with a "poor" Cam Follower Pin (and having the lift arms drop as far as they could possibly go) so maybe I'm just used to incorrect operation.
What is the spec travel distance for the rear lift arms? Or, to ask it another way, what are the spec distances from the rear of the lift arm to the ground in the upper and lower positions (accounting for variations in tire size, etc.).
Thanks!
Thanks!
