Company Logo Shop Now
TractorLinks.com
Fuel supply to carburetor problem
bobbyjack
04-15-2019 08:32:41
I have a Ford jubilee tractor. The tractor starts fine and runs for about 5 minutes then dies....if I wait 10 minutes it will start and run another 5 minutes. Apparently gas is flowing slowly out of the tank or through the sediment bowl. I disconnected the fuel line at the carburetor and put gas in a 5 gal plastic container with a tube running into the supply line for the carburetor. The tractor runs fine then. I have replaced the sediment bowl, ran a wire through the supply line from the sediment bowl to the carburetor to clean it out, changed filter going into carburetor. I have taken the gas tank off and cleaned it out.....nothing notable inside...a few very small specs found. Any suggestions?
Jim L WA
04-15-2019 09:22:14
 Re: Fuel supply to carburetor problem in reply to bobbyjack, 04-15-2019 08:32:41
Also, you can remove the gas tank cap, and see if it runs more than 5 minutes. You might have a plugged vent in the cap.
showcrop
04-15-2019 09:00:37
Open the tank shut-off with the line disconnected at the carb. Does it run freely. If not, put it back together there, and disconnect at the tank tap, and open the shut-off. Does it run freely? If not it is your tank tap.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
