So a little bit ago my charging light was on so I replaced my voltage regulator and behold, light went out.
Fast forward, I learned the hard way one night while running with my lights on it was in fact not properly charging once I shut the tractor down and tried to fire it back up.
Here are the symptoms:
-At night the charging light is very dim but you can see that it is slightly lit.
-When I turn the lights on while tractor is on, disconnect the battery hot so it runs off the genny, my LED lights flicker on and off very rapidly and dim.
From those symptoms I have obviously deduced something is wrong with the charging system.
I have tried polarizing numerous times to no avail.
Replaced the Generator today ... still same issue.
What am I missing?
What am I missing?
