Need some help with 201 ford diesel 3 cyl block. I bought the 4500 with front loader. I went to fill radiator and block with water / antifreeze. discovered water leak from what appears to be the block at the starter. I think I will have to pull the engine to see how much damage was done. looks like someone did not drain block properly.
My main question is how hard would it be to find a block and normal cost ,, also a good location close to Ashland ky. to find a block ? I do not know if it can be repaired till I pull the engine. Any suggestions ? Thanks Randal
