Signal Stat Flasher?
tjcc1978
We need to replace this flasher:
signal stat 170 12 V flasher. says 257 on the side. Does anyone have one or know where I can get one? I tried our local tractor store, nothing. Tried New Holland parts, nothing.....
I would try a turn signal flasher for a car from the 70's. If I remember correctly I think some even had the
same spade orientation as the one in your picture.
552's I have searched for, and they are all circular. This is rectangle. Needs to be rectangle or it won't fit.
This flasher is for the amber lights on the rear of the tractor....I have found brand new 175's on ebay, but do not know if that will work.
Could you use a round flasher and make a jumper harness to mount it remotely from where it currently plugs in? Standard 1/4" spade terminals should work.
-Scott
https://www.amazon.com/Dewhel-0-02A-10A-Electronic-Flasher-Signal/dp/B07JFPXM21/ref=sr_1_16?hvadid=190461254864&hvdev=c&hvlocphy=9028101&hvnetw=g&hvpos=1o2&hvqmt=b&hvrand=11507896804525169050&hvtargid=kwd-296080959251&keywords=flasher+for+led+turn+signals&qid=1553357875&s=gateway&sr=8-16
or
https://www.amazon.com/Sdootauto-Motorcycle-Adjustable-Flasher-Indicator/dp/B07F1M9579/ref=sr_1_18?hvadid=190461254864&hvdev=c&hvlocphy=9028101&hvnetw=g&hvpos=1o2&hvqmt=b&hvrand=11507896804525169050&hvtargid=kwd-296080959251&keywords=flasher+for+led+turn+signals&qid=1553357990&s=gateway&sr=8-18
the first one is rated for 10 amps so should work ok.
Thanks for these, but that first one the pins are not in the right spots. Might see about the second one.
