641 ford tractor diesel
I have a ford 641 diesel tractor just bought it. Injector pump is leaking diesel into oil pan. I have found tag with injector pump # just need to get paint removed to get a number for it. where is the tractor serial # located? what is procedure for timing the injector pump when I reinstall it?
Remove the two screw cover on the pump side, then after the fuel stops running out turn engine by hand until the timing marks align inside the pump. Much easier to go back on IF the timing was set before pulling the pump.
Ditto what diesel tech said about timing.
Model and serial numbers of that tractor are lightly stamped in to the flat spot on the bell housing behind the starter. It is possible that they've been eroded away by battery acid on a diesel.
Have you checked inside the valve cover to see if the return lines are leaking? sorry if this is redundant.
