Posting question for a friend
grandpa Love
He has this posted on Facebook. I
did a screenshot and posted here.
Any ideas to fix this issue ?
Thanks!
<img
src="https://www.yesterdaystractors.com/cvphotos/cvphoto17163.jpg">
Fixed your image link:
check the linkages from one end to the other - if everything is in order is sounds like a governor problem -
David
Stop using it, and get the injection pump repaired SOON! The weight retainer flex ring is coming apart causing the trouble. Just finished repairing a JD 3010 injection pump for the same trouble. Pump is repairable now, if it's run much longer it WON'T be..
Quick Google search of flex retainer ring thing brought me to yesterday's tractors!! Found a great post about replacing it. Thank you. Info was w forwarded to my friend , hopefully it will solve his issue.
(quoted from post at 11:16:46 03/20/19) Stop using it, and get the injection pump repaired SOON! The weight retainer flex ring is coming apart causing the trouble. Just finished repairing a JD 3010 injection pump for the same trouble. Pump is repairable now, if it's run much longer it WON'T be..
Ditto this!
