Company Logo Shop Now
starting tractor with loader off
801 Powermaster
03-20-2019 01:55:25
I am starting to swap all the parts from one tractor that had a loader that runs off the pump mounted on the engine. When I get it all put on my 3600 what needs to be done to run it before I get the loader back on it with out burning the front pump up.
Destroked 450
03-20-2019 06:34:30
 Re: starting tractor with loader off in reply to 801 Powermaster, 03-20-2019 01:55:25
That's his plan, the yellow tractor is a 3500 with a bad SOS trans.
The 3600 has a torque convertor trans and rear axle like a 340 utility.
He's going to swap the 3500's front axle and steering onto the 3600's chassis
He'll need up with a home made version of the 420 industrial.
Then he's going to sell the left over parts.
showcrop
03-20-2019 04:33:13
I can't imagine why you would do all that taking apart. Why can't you just suspend the loader from the back end, drive the tractor in, then lower the loader to where you can drive the axle over the back frame? Then all you need to do is jack the loader up into position.
801 Powermaster
03-20-2019 03:32:13
OK, I will not start it. I thought about this. Here is what I am working with. I learned I should have removed the side cylinders first and then pulled the pins and then removed each arm on the tractor. I need to do it this way when I put it back on.
Its all going on my 3600
mhb@ufe
03-20-2019 04:42:56
 Re: starting tractor with loader off in reply to 801 Powermaster, 03-20-2019 03:32:13
How are you going to mount the front of the loader? Your 3600 doesn't have the cast front axle support.
Mark
Ultradog MN
03-20-2019 04:38:03
That is a Lot of loader for the front end on that Blue tractor - whatever it is.
Did we ever establish exactly what it is?
I would be tempted to put the industrial front under it.
RickB
03-20-2019 02:49:41
Donít install the pump before the loader goes on.
Today's Featured Article - Box Plow Blues - by Tom Schwarz. One of the first implements most tractor owners obtain is the box plow. For very little money, this piece of equipment promises to plow and flatten any hill or vale on your ranch road or farm. At least that's what I thought! As simple as a box plow appears, it can be rather challenging to make work correctly. In our sandy soils of Florida, traction is king. You can never have wide enough tires or heavy enough weights to get all the traction you want Ö unless you own a monster tractor. U ... [Read Article]
Latest Ad: Oliver model 101 1-16 rope trip plow on steel. Includes new share/point and great mouldboard. 300 [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
