After my tractor's long winter nap, I started it and attempted to raise the three point hitch as I wanted to use the boom to lift and move some stuff.
Instead of the lift arms raising, oil started blowing out from under the pump where it mounts to the chassis. This is a new. The three point hitch worked just fine before winter and now, it isn't working at all.
This appears to me to be a gasket issue, and that seems fairly straight forward. However, I could be wrong. I really don't know any more than I have said and what is shown in the photo.
This is a new "fix" for me. Are there any aspects of this work that might something of particular to note while making the fix?
I suspect that I should also drain the remainder of the oil that is in the reservoir and replace all of it too.
I appreciate any input or feedback any of you may have regarding this repair.
