5 speed double ctuch input shaft slop
riveroadrat
I now know where the slop in the input shafts come from. The PTO input shaft thrust washer and the transmission input shaft thrust washers. They are fudgeable, you can put a thicker PTO thrust washer on and it will take some slop out or you can put new thrust washers on the transmission input shaft to take out some slop. None of the thrust washers are available from CNH. I bought some 2"x 3" bronze washers off fleabay and will have them turned down to 2 1/2" outside and have the face shaved some. Factory width is 1/16" on the PTO thrust washer.
