Company Logo Shop Now
TractorLinks.com
Re: Ford 1310
Bern
03-14-2019 19:39:19
There's no way the injection pump timing is off far enough that it won't start. That model of pump uses shims for timing, and even if the shim(s) were lost, it would still run.
Bob N.Y.
03-15-2019 04:21:19
 Re: Ford 1310 in reply to Bern, 03-14-2019 19:39:19
Is it possible the pump is 360 degrees out of time so the fuel is being injected at the end of the exhaust stroke? I saw that happen on an Oliver 1650.
Jcarpenter
03-15-2019 04:11:22
Thatís what I have read. Iím going to change out the fuel, but not sure why it wonít run. Any safety switches you know of on the motor. I believe it might be a Yanmar.
Dieseltech
03-15-2019 05:19:56
 Re: Ford 1310 in reply to Jcarpenter, 03-15-2019 04:11:22
Most Ford small diesels were built by Shibaura, and used the inline PFR injection pumps similar to Yanmar and Kubota. I'm with Bern, pump won't be out of time UNLESS the cam inside the engine has failed somehow..
Jcarpenter
03-15-2019 06:20:55
 Re: Ford 1310 in reply to Dieseltech, 03-15-2019 05:19:56
Donít smell like gas, but Iím going to drain tank and put fresh fuel in it. Motor has never been disassembled so should be good on timing.
Jcarpenter
03-15-2019 13:16:58
 Re: Ford 1310 in reply to Jcarpenter, 03-15-2019 06:20:55
Added fresh fuel, re bleed lines and still wonít run only cranks. Does hav white smoke coming from exhaust.
flembo
03-15-2019 15:26:27
 Re: Ford 1310 in reply to Jcarpenter, 03-15-2019 13:16:58
Does that engine have the glow plugs to help it start by turning the key ccw for 10 or 15 seconds before starting. My 1710 starts much better after using that, before I knew about that it would crank and crank before starting I soon learned about it.
Jcarpenter
03-15-2019 15:40:19
 Re: Ford 1310 in reply to flembo, 03-15-2019 15:26:27
Yes. I checked them and they work, but hasnít made a difference.
