Jcarpenter
New User
I have a family Ford that has come to my use. Bad part it will not start. It?ll cycle but won?t fire at all. Tractor has 270 hours on it.
The last time it was ran was October 18 and then parked. For some unknown reason my uncle thought injector pump was bad so he had it checked but it was good. He put it back on and since has not started. He tried to start it with starting fluid but it didn?t even try to run.
Ive bleed the fuel lines all the way to the injectors but still won?t run and only cranks. I?ve not taken The injectors our to see if their spraying.
I?ve also got a manual for the tractor but the fuel pump runs off the cam, so could not time it.
Any ideas?
Any ideas?
