Company Logo Shop Now
Dean 5 speed keyway fix
riveroadrat
03-11-2019 06:28:19
On my other post you mentioned to get a good used shifter rod, I have one. Do you know if the shifter rod can be removed independently by itself?
Dean
03-11-2019 07:46:28
 Re: Dean 5 speed keyway fix in reply to riveroadrat, 03-11-2019 06:28:19
I've not overhauled a 5 speed transmission, RR, so am not certain, but I do not believe that it can be. Perhaps Bern knows.
Don't you have the transmission out already for replacement of a thrust washer or something?
Dean
riveroadrat
03-11-2019 08:33:56
 Re: Dean 5 speed keyway fix in reply to Dean, 03-11-2019 07:46:28
I had a problem with 3-r but it was just a broken detent spring. I don't need to pull it now. The manual just gives breakdown instructions. I'm pulling the input for seal replacement. I have another one split that needs a 311266 thrust washer. The parts manual is a little fuzzy on that washer as it shows it for the single input and the double input. I know that the single has those 3 washers on the tranny input just like the double does. There's really no place for it on the single input as it already has those 3 washers but the double pto shaft that i took out of the other tractor didn't have a bronze washer between the pto input gear and that big steel washer that HoboNC said that he belled with a press to give it more width.
Today's Featured Article - Antique Tractor Wiring Basics - by Curtis von Fange. One of the most neglected parts of old tractors is the wiring. After sitting in the elements for half a century or more much equipment wiring has deteriorated to sparsely covered strands of copper or other metal. Plastic insulation has cracked, mice have eaten through the older clothed style coverings and the exposed wires have reacted to winter moisture and salts by turning blue and powdery. Terminal ends have corroded, rusted or just plain evaporated away. Aged wires not only keep an engin ... [Read Article]
Latest Ad: Looking for a John Deere 50, 520 or 530 in good shape and preferably with power steering and three point. May be interested in a 620 or 630. Thank you. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
