Still puttering around on the 3 cyl gas 2000. When running it
the other day, I noticed a slight trickle of hydraulic fluid leaking
out the end of the hose connector. Just a slight amount, but
noticeable if you sat there watched. The back of the tractor
was caked in sludge, I?m guessing this had gone on for quite a
while. Fluid was really low in the rear end when I dropped it
too.
Is this an issue in the valve assembly itself, or something
clogging up in the connection assembly? Thoughts
appreciated.
too.
appreciated.
