Hi, I have a Ford 4500 TLB, Sept '69 that has a 13" & 15 spline clutch. Trying to put a new clutch & pressure plate in it & can't get the clutch to disengage. Adjusted everything & now adj. free travel out & still can't get clutch to disengage. 4 shims about .0100 thick between flywheel & pressure plate.
Have tried everything & can't get to work. Apart & together, apart & together several times!!
Thoughts? Will ck back later.
