901 lift arms
Tom Bond
Does anyone know if the lift arms are the same size for a 901 and an 801? Set on fleabay advertised for an 801. Just wondering if they would mount on my 901? Not sure about the lengths. Thanks
They are longer so they can get closer to the ground. You could always cut off one end and weld a new one on to make it longer. There is a post on here somewhere about lift arm part numbers and length's, and also one on hole positions, I think. Try searching it on Modern View. 801 arms will work but if you have very large tires they might be a little short.
