(quoted from post at 22:11:05 03/06/19) checked the # again and it is 9H04B
(quoted from post at 09:08:56 03/08/19)
Thanks for the info. I will check it out when the weather is agreeable here in eastern Ky.
(quoted from post at 14:42:18 03/11/19) Well my buddy looked at my 4500 and said it was the smaller pump. he has the 4500 with factory hoe. I was thinking that I could put a t in the pressure side and a t in the return side at the loader valve bank and supply hose the oil to the pressure side of the valve bank for the hoe as well as the return side of the same valve bank. ??? that way constant pressure would also be routed to the return side so as not to damage anything. what do you think ?
(reply to post at 20:15:34 03/11/19)
