riveroadrat
First let me ask you pro's about this one thing. Why is there so much slop on the input shafts of these live PTO tranny's? Is that what makes some of them rattle? I am looking at two right now that have at least 1/8 inch in and out free play on both tranny and pto shaft. I have two that don't rattle and three that do, one of them profusely. Now to the clutch adjustment. Given the geometry of the throwout bearing yoke, it appears to me that the further forward the yoke moves that it loses travel as it is pressed toward the clutch. Would i be correct on that? Also pertaining to that movement, every double clutch I have seen has the screws threaded about halfway in. It seems to me if they were screwed further out that it would give more action with less pedal movement, although they might need locking nuts to make sure they don't come out of adjustment. Also on the locking nuts. Would there need to be an equal amount of nuts to keep it in balance? Any and all info appreciated. I was looking at the shafts down through the steering box hole and noticed how far away the finger screws were away from the throwout bearing before it ever contacted them. That's what got me started on this adjustment thing.
