the1cadman
New User
I have acquired a 7700 with water in the oil. Its FREE! NOT!
With out a lot of detail, here are the facts. Was running when parked, old man got Alzheimer's, family let it sit 4+ years...
1. Rusty Exhaust... water is turbo, intake and into the head.
2. Crank case full of antifreeze. its on the Texas Coast, don't think its cold enough here is crack head or block, but machine work will tell.
3. Hyd Hoses probably need replaced, but that's a maintenance issue.
4. Fuel tank was drained.
5. injector lines have serface rust, but no seepage, seems still intact and sealed
Tires are still in great shape, look new, still hold air/fluid.
Name place numbers:
tractor number: c534980
model: (E oe F) c2150
Unit: 7c28b
Engine: 7b22b
Trans:7a27
Hyd Pump: 6m22b
Rear Axel: 2a28b
Hyd Lift: too damaged to read
Labor is free.
Is this worth the rebuild? I need it for Hay and property clean up.
I cant determine which turbo is on this, but it has switzer on it, possibly 2 types, 1 is 350.00, the other is 1100.00...
Has front end loader and hay spear.
Any advice is appreciated...
Name place numbers:
Unit: 7c28b
Engine: 7b22b
Trans:7a27
Hyd Pump: 6m22b
Rear Axel: 2a28b
Labor is free.
