Company Logo Shop Now
Followed me home
Royse
02-22-2019 16:30:48
This one's going to need a bit of work, but I've been looking
for one for a while now, so I bought it. 1958 (I think) 1841.
Good 16.9 x 24 rears, full set of pie weights, Sherman reverser,
Ford loader with no cracks or welds anywhere that I could find.
Came with a replacement engine and spare front axle to boot.
Good thing, because it's going to need that engine.
indford
02-24-2019 10:39:04
 Re: Followed me home in reply to Royse, 02-22-2019 16:30:48
Nice, I think you will be happy with it. Seems like it was well taken care of, the hole in the block might have saved this machine from becoming all busted up. I have one of those air cooled engines too! Looks like it might be still wearing itsí original paint,I like that color combination. Not too common to find one that is not all busted and welded up. The loader and backhoes on these machines were overpowered and donít know stop. I have found that they like to crack right at that bend on the frame where the loader mounts. Itís good to checked them out real well to catch the small cracks before they become big cracks. I have a couple of them now, okay more like a few. It's an addiction, the wife has me in a recovery program now, we meet every other Wednesday at 8. There is nothing like the high of a freshly bought tractor! It has been about a year since I bought my last one Ö.
Kirk-NJ
02-24-2019 00:13:31
Nice find Royse. Appears to be an 1841 with later 4000 HD steering box. The sherman handle on the 1841 would have been the dogleg style but the dogleg handle hit the later 4000 steering arm so they changed to the straight handle, as shown on my 4000 HD. Appears they just hack off part of the dogleg handle and added a gear shift off a riding mower. The wheel weights appear to be the heavy weight lip style for the rim. If you take them off would be curious to see if there's a W8 on the back. While you have the engine out check for cracks at the bend in the frame. Easier to get a good weld on the inside with engine out. Good luck with the new project.
indford
02-24-2019 13:38:13
 Re: Followed me home in reply to Kirk-NJ, 02-24-2019 00:13:31
Kirk-NJ,
Do you think it could possibly be a reverser that when they changed out the steering box they made do with a welded on handle? Maybe the linkage was missing or damaged.
Hereís a picture of an 1821 late 1958 Gas with the Sherman combo..
And an a 1821 early Diesel with the Sherman Reverser
This is an 1841 later diesel with the shifter handle.
Kirk-NJ
02-25-2019 00:21:47
 Re: Followed me home in reply to indford, 02-24-2019 13:38:13
Yes might also be a reverser, anything is possible. Here's one made up for my 8n cause it hit the mounting plate for the one arm loader. I've seen busted handles get welded up in all kinds of positions.
Colin King
02-23-2019 13:40:08
Nice find!
Colin
Dean
02-23-2019 05:55:43
Ran when parked?
Dean
Larry NCKS
02-22-2019 23:48:28
:shock: 8) :lol:
scoutfisher
02-22-2019 21:10:57
Got one like that.
Royse
02-22-2019 18:09:09
It was an interesting day Larry. The driveway up out of where that
tractor was, to get to the shop to load the replacement engine, was
a winding, uphill drive. I didn't get going fast enough to make it up
the hill the first time. I thought I had enough weight to make it
work without going too fast and sliding off one of the curves.
2018 F250 with four wheel disk brakes, 14K trailer with brakes on
all four wheels, all 8 wheels locked up and still sliding backwards,
back down that hill. Tractor/loader/bucket/pie weights/16.9 x 24
loaded tires/spare front end all loaded on the trailer already.
What's that? 15K pounds or so?
Nothing I could do but let off the brakes and steer the trailer back
down the hill to get a better running start. It worked out fine.
I think I twisted that tail hard enough. Thank goodness for good mirrors!
Royse
02-22-2019 17:53:46
Yep, no cables Jerry. Replacement front axle has a rebuilt cylinder
and new hoses. The current front end has one sloppy king pin.
Other than that, it looks good too.
I have to take it off to replace the engine anyway so I'll swap them.
Won't happen until summer though. Getting that loader frame off
is going to be quite a bit of work I think. I've never done an engine
swap in an industrial, so it will be a learning experience.
Ultradog MN
02-22-2019 17:42:11
A true loader tractor.
Nice.
Looks like you got the late style steering which is a big plus over the early cable rig.
warbaby
02-22-2019 17:29:15
Northern Mi. Craigslist! Looked like a good deal..
Larry NCKS
02-22-2019 17:15:54
How hard did you have to twist its tail to get it to follow you? :lol:
pomester
02-22-2019 16:45:21
Nice - I've always liked the appearance of the industrials - I've got a 960 with a block with a hole in a similar position - the pieces were welded back and altho the area seeps just a little bit the engine runs fine - all done before I got it -
I hope you'll post some pictures as you work on it -
David
felix donnelly
02-23-2019 14:07:42
 Re: Followed me home in reply to pomester, 02-22-2019 16:45:21
I have two HD Industrials one Elenco 4x4 and the other two wheel drive, Iím always impressed with the lifting capabilities of these tractors. Both of mine were cable steer which I had to change out. Yours looks like a great machine and a plus to find with a nice set of 24Ē wheel weights and already has the drag link steering. Iíll try to post a picture of the Industrial I picked up last April. Good luck with your project.
Today's Featured Article - Product Review: Electronic Ignition - by Staff. Oil, for example has come a long way in the last 50 years and I don't use anything but the latest API grade available. I've heard the arguments for non-detergent oils but would never trade it for today's formulations. Paint is another, the modern acrylic enamels are great for resistance to grease and fuel stains, retaining their shine and they last forever; unlike enamels and lacquers . Still another is the alternator. No doubt using the original generator keeps the tractor pure, but for thos ... [Read Article]
Latest Ad: Armstrong 11.2x24 4 ply new never run,mounted on Allis B or C rim [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
