zep
New User
I'm wondering what front axle pin and bushing I need for my ford 841 it has the adjustable wide front end. I do have the Elenco front end but the pin looks stock.Thanks Zep
The elenco used the same axle off his 841 to carry the rest of the elenco set up. Different of the HD industrials.
not sure here, going from memory... oh boy and away we go. There was a heavy duty front AG axle with the larger pin, They where non industrial and had a decal on the lower front sheet metal that id them as
heavy duty front end.
As Kirk says...gonna be the standard pin. The heavy duty pin has hex head and threads on the end, also uses the big thick bushing.
Thanks for all the comments and help.I found the pins on this website but not the bushing?Where have you guys purchased the bushing at?ThanksZep
This site has them...try part number 2n3039 $7.28. Note the dimensions and compare to your tractor's bushing.
