3000 lift trouble
My 1972 gas 3000's 3-point lift is unresponsive from the bottom of the lift range adjustment until the lever is almost at the top. Once it's almost at the top, the lift
raises all the way to the top. Any down adjustment on the lever drops the lift all the way down. With any weight on the lift, such as a bush hog, there's a noticeable
thump as the pump runs, and the lift leaks down rather quickly on shutoff.
Where should I start?
Thanks.
