I'm having an issue with my 3 point lift on my 850 and I can't seem to find anything similar when I search.
When I lower my 3 point past a certain level it will not raise on its own unless you manually raise the lift bars up about 8-12 inchs I would guess. it then "catches" and raises the rest on its own.
Also, when I lower it halfway it seems to creep down. When its fully raise with tractor running it will stay there. It may slowly creep down when shut off, but not instantly. I can't remember.
I have a loader and it works fine, so ruled out hydraulic pump issues.
I bought a gasket/piston seal kit, but before I tore into it I wanted to know what to look for.
Thanks in advance,
Joe
Thanks in advance,
Joe
