I finally gotten 2000 running! Still have to put the radiator back on, so I haven't gotten it out and run it hard. I did try the 3 pt, no movement at all. I pulled the lever for the remotes, got a quick blast of air and then it sprayed fluid everywhere. Do I need to bleed air out of the lines before I will get pressure to the 3 pt? I'll have to round up a clean bucket if that is the case, I don't need any more fluid coating the shop and everything in it. Is there another place to bleed the system? Gonna dig into the manuals tonight as well. Anything else I should check? Drained all fluid out and put fresh oil in a week ago.
71 3 cyl gas.
71 3 cyl gas.
