Company Logo Shop Now
Order Ford 2000 Parts Online
2000 hydraulics
edhOH
02-17-2019 12:42:48
I finally gotten 2000 running! Still have to put the radiator back on, so I haven't gotten it out and run it hard. I did try the 3 pt, no movement at all. I pulled the lever for the remotes, got a quick blast of air and then it sprayed fluid everywhere. Do I need to bleed air out of the lines before I will get pressure to the 3 pt? I'll have to round up a clean bucket if that is the case, I don't need any more fluid coating the shop and everything in it. Is there another place to bleed the system? Gonna dig into the manuals tonight as well. Anything else I should check? Drained all fluid out and put fresh oil in a week ago.
71 3 cyl gas.
Bern
02-17-2019 13:40:16
 Re: 2000 hydraulics in reply to edhOH, 02-17-2019 12:42:48
If the remotes work but the 3 point does not, then you have a stuck unload valve in the lift cylinder. Many posts in the archives about this issue.
Today's Featured Article - The Niagra View Mobile - Powered by a 1959 Ford Tractor - by Mark Massey. In 1959 the Niagara Frontier Transit Inc. of Buffalo, New York designed and built six Viewmobiles for the Niagara Frontier Sightseeing Inc. for use as a sightseeing ride at the Niagara Falls State Park, Niagara Falls, New York, powered by a 1959 Ford 611 Tractor. ... [Read Article]
Latest Ad: Hiniker 1300 rear window frame looking for one closer to Iowa the better [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
