Company Logo Shop Now
No reverse
600Bill
02-15-2019 08:36:41
I have a Ford 650, When going down a small hill in 3rd gear I heard a banging noise, when I put the tractor in reverse the banging got worse and the tractor wouldn't move. The noise seems to be coming from the axle, but it was hard to tell while sitting on the tractor. Any suggestions?
sunbeam
02-15-2019 16:21:57
 Re: No reverse in reply to 600Bill, 02-15-2019 08:36:41
Remove rear end fill plug have some one try backing up while you look with a flashlight to see if the ring gear is turning.
Larry NCKS
02-15-2019 15:27:20
Don't think he said that, did he? It's not going fine in others if it's popping on a downhill run.
BigDanT
02-15-2019 14:18:56
I'm probably way off base here but, I thought third and reverse gears were coupled together on the countershaft in the 5 speed. I wonder if some how this could be related, especially since you don't seem to have reverse gear now and it does fine in the others.
warbaby
02-15-2019 14:52:29
 Re: No reverse in reply to BigDanT, 02-15-2019 14:18:56
3rd & reverse ARE the topmost 2 gears on a 5 speed's shifting tower.....
3-R 1-2 4-5
Larry NCKS
02-15-2019 12:58:34
I'm still guessing broken axle. Sometimes they drive one direction and snap end over end the other. That would account for both your downhill scenario as well as lack of reverse.
BigDanT
02-15-2019 11:52:38
Was the tractor able to move or make noise when put into the other gears?
600Bill
02-15-2019 12:47:57
 Re: No reverse in reply to BigDanT, 02-15-2019 11:52:38
It goes fine in other gears. It did make noise going downhill, but not up.
Larry NCKS
02-15-2019 10:11:02
Broken axle???
Today's Featured Article - Recollections of a John Deere GP - by Charlie Cook. I grew up on my dad's 280 acre general farm in Western Michigan. Dad's only tractor when I was very young was the old GP. My first recollection of this tractor was when dad allowed my brother and myself to ride on the tractor with him driving. One of us would sit on the left fender (away from the clutch) and other would sit on the gas tank and hold onto the crankcase breather pipe. ... [Read Article]
Latest Ad: Wanted front suit case weights and rear wheel weights for a 1456 international. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
