catalina0029
I have taken apart the PTO clutch to replace the O-rings and inspect the plates. This is a single speed PTO in an S-O-S transmission.
The piston has an O-Ring in the bore of the piston, size 142, no problem there.
The outer seal that was in the piston is a rubber rectangular seal. The parts list shows this seal as IP-77513A Seal, Trans. RR CI Piston Oil, Outer
The dealer gave me part number C5NN-7C000-A which is a cast iron ring. The piston has part number 312055 cast right on the piston. Neither of these numbers even show up on the NH web site. The piston ring fits fine.
Can I use the cast iron piston ring with this aluminium piston # 312055?
