a few weeks ago there was a thread about an LP tractor - that jogged my memory of a 961 I purchased 20+ years ago that had an LP system installed - it was not a factory install as the tractor still had a (dirty) gasoline tank - the seller included a gasoline carburetor and after an overhaul I still have the tractor -
it took me a month to remember/figure out where I had stored the LP system - I thought I would post some pictures and maybe others would have thoughts to add -
David
the carb
bottom of carb
regulator, I assume - it has an electric heater attached so I assume coolant must be routed thru the system to keep things at desired temperature
info on the regulator
don't know what this is -
the tank - mounts on the front of the 9XX series to the large bolt holes at the top of the pedestal - heavy, I didn't get a good picture - there are multiple valves and a gauge on the top of it -
David
the carb
bottom of carb
