The 640 PTO jumps out of gear. While cleaning out the hydraulic section I took the PTO shifter rail apart.
Looks a little worn so I turned the rail over and stretched the detent spring a 1/8 inch more. It was a tough little spring.
Put it back together and it seems as if it is now harder to engage and disengage the PTO. Maybe this will fix the problem.
