Company Logo Shop Now
TractorLinks.com
LP system
pomester
02-10-2019 19:53:13
a few weeks ago there was a thread about an LP tractor - that jogged my memory of a 961 I purchased 20+ years ago that had an LP system installed - it was not a factory install as the tractor still had a (dirty) gasoline tank - the seller included a gasoline carburetor and after an overhaul I still have the tractor -
it took me a month to remember/figure out where I had stored the LP system - I thought I would post some pictures and maybe others would have thoughts to add -
David
the carb
bottom of carb
regulator, I assume - it has an electric heater attached so I assume coolant must be routed thru the system to keep things at desired temperature
info on the regulator
don't know what this is -
the tank - mounts on the front of the 9XX series to the large bolt holes at the top of the pedestal - heavy, I didn't get a good picture - there are multiple valves and a gauge on the top of it -
pomester
02-12-2019 06:46:21
 Re: LP system in reply to pomester, 02-10-2019 19:53:13
I'm in north-central Indiana - I'm also off to meetings until Thursday evening, I'll be back here then - my email is open in classic view - probably more interested in trading than money - I need a SOS PTO cable assembly, a presentable set of 9X1 rear fenders, or ??? - I'd meet half-way in the right situation -
David
pomester
02-11-2019 19:12:21
"What are you wanting to do with this stuff?"
find it a home - I'm not going to use it and there's no point in putting back into storage - it's been stuffed in a bucket in an outbuilding for several years, time to move it on if there's someone to use it - if not, it's time for the scrapper
agjim
02-12-2019 01:48:36
 Re: LP system in reply to pomester, 02-11-2019 19:12:21
Where are you located and how much are you asking for it?
da.bees
02-11-2019 15:12:11
Shaun Wallace
02-11-2019 06:16:35
The copper tubing with black thing is fuel filter.
