Company Logo Shop Now
TractorLinks.com
Order Ford 640 Parts Online
640 PTO jumps out of gear.
pburchett
02-10-2019 16:35:57
The 640 PTO jumps out of gear. While cleaning out the hydraulic section I took the PTO shifter rail apart. Looks a little worn so I turned the rail over and stretched the detent spring a 1/8 inch more. It was a tough little spring.
Put it back together and it seems as if it is now harder to engage and disengage the PTO. Maybe this will fix the problem.
pomester
02-11-2019 17:40:38
 Re: 640 PTO jumps out of gear. in reply to pburchett, 02-10-2019 16:35:57
the bearing should be tight between the collars - I can see ~3/8" where the shaft is free to slide thru the bearing - I use heat to expand the collar so it adjusts easily -
at this point, make a critical evaluation of the bearing and collar condition - neither are particularly expensive and it would be easy to replace both plus the seal now -
David
pburchett
02-11-2019 17:28:15
I guess this is the retaining collar I have marked with the arrow. I will look at the internal end of the PTO shaft tomorrow, but I did not notice any wear when I took it out.
The other end shows some wear but I believe it is from the over run coupler. I will check the end play when I put the shaft back in as I am waiting on parts from YT. I think Washington / Idaho had some bad weather which is delaying my parts.
soundguy
02-11-2019 08:29:13
Ditto what Pomester said. make sure there is no thrust play.. that will walk them out of engagement, and mushroom the end, and chew the splines
Post back.
pomester
02-10-2019 16:41:14
check for end play of the PTO shaft - if it is excessive it will cause the PTO to jump out. It is controlled by the retaining collar near the bearing.
Fast Shipping!  Most of our stocked parts ship within 24 hours (M-Th). We have the parts you need to repair your tractor - the right parts. Our fast shipping, low prices and years of research make us your best choice when you need parts. Shop Online Today. [ About Us ]
Copyright © 1997-2019 Yesterday's Tractor Co.
