Order Ford 901 Parts Online
Re: does a 901 have live hydraulics
Bern
04-21-1999 17:07:00
Yes indeed, your tractor does have live hydraulics, courtesy of the engine mounted pump on the RH rear of the engine block. The output from this pump goes straight to the lift cover, so the 3 point is live all the time. It is not dependent on whether or not the tractor has a remote valve mounted, as stated in the prior posting. Also, the PS (power steering) has it's own pump and is not dependent on the tractor hydraulics.
