Company Logo Shop Now
Order Ford 600 Parts Online
Ford 7600 Question...
joethetractorguy
02-07-2019 15:39:01
Hi, new to the forum, but have been reading for a long time. I recently purchased a Ford 7600, serial # FA215C-1KO1B-C677263 (1981 with 268 Blue Power Special engine). I have been replacing the PTO shaft and sleeve, as they were missing when I bought the tractor. The odd thing is, although I have read numerous times on this and other forums, this tractor does NOT have a Load Monitor. It also does not have Dual Power, just an 4-speed with Hi/Low. It is also painted yellow! It seems to be a tractor that Ford never built. I have not seen or heard of another one like it, even on the interweb. There are no levers for dual power, and the Three-Point lever does not have a Load Monitor position. I am baffled. Is it possible Ford would have built an early 7610 and put 7600 tin on it? The date code states 12th month/81. Anyone who could chime in on this please do. Thanks in advance!
Sean in PA
02-07-2019 17:04:59
 Re: Ford 7600 Question... in reply to joethetractorguy, 02-07-2019 15:39:01
Parts site shows many parts in the top cover drawing listed as "W/Load Monitor" (With Load Monitor) and many others listed as "L/Load Monitor" (Less Load Monitor), so it looks like Load Monitor was definitely optional.
joethetractorguy
02-07-2019 17:22:56
 Re: Ford 7600 Question... in reply to Sean in PA, 02-07-2019 17:04:59
Well I'm somewhat happy about that, as the previous owner said it was having PTO issues, which is why the PTO shaft and sleeve was missing from the tractor. I was dreading doing a rear end split to fix it, considering the Q-cab removal required to do it. Still waiting on my new PTO shaft to arrive, but if it turns out to be a PTO clutch problem, or something else, can this be done through the rear cover, or is a split still the easiest way?
sotxbill
02-07-2019 16:32:35
Your serial number is 17000 into the 81. Your build date is 10/01/1981. However your FA2 says its a 7600 from 76 to 80?
Only thing I can figure is that it was a special order, and they grabbed the 7600 parts to build a tractor to meet the specs for this order. For city, state orders they did do special builds.
joethetractorguy
02-07-2019 17:16:17
 Re: Ford 7600 Question... in reply to sotxbill, 02-07-2019 16:32:35
That is very interesting, thanks for the insight! The tractor also has an electronic ether start option, in lieu of a thermostart. Not to sure if this is factory or not, but looks to be considering the decal below the push button. Was this also common on a 7600? It is also worthy of noting that certain elements of the tractor (such as the Q-cab, auxiliary fuel tank, front axle and air cleaner cover, however not the radiator shell or hood) look to have originally been painted blue, then yellow, while the engine, rear-end and tranny were not, they were only painted yellow. Seems like a real mish-mash of a tractor to me. But none the less, pretty cool to see. Obviously not a rare tractor, but unique :)
farmman2600
02-07-2019 16:15:20
Iím not an expert at all, nor claim to be. Iíll tell you what I understand to be true about these tractors. I may be wrong but this is what I understand. The 7600 is the utility version while the 7700 would be the row crop, which would have come with dual power as an option and almost all of them came with it. With the 7600 being the utility with the option of dual power, I assume as many did not come with it. Like I said this is just what Iíve learned from others as Iíve been looking. Hope this helps.
Fordfarmer
02-07-2019 16:08:07
Dual Power was optional, Load Monitor may have been, too. Yellow paint would suggest it was a state or county owned tractor.
RickB
02-07-2019 16:23:26
 Re: Ford 7600 Question... in reply to Fordfarmer, 02-07-2019 16:08:07
And a state bid or municipal specíed tractor would be very likely not to have DP and LM options.
sunbeam
02-08-2019 07:20:09
 Re: Ford 7600 Question... in reply to RickB, 02-07-2019 16:23:26
I have a 1991 7710 II that was a Tiger mower tractor with out load monitor.
Today's Featured Article - Antique Tractor Wiring Basics - by Curtis von Fange. One of the most neglected parts of old tractors is the wiring. After sitting in the elements for half a century or more much equipment wiring has deteriorated to sparsely covered strands of copper or other metal. Plastic insulation has cracked, mice have eaten through the older clothed style coverings and the exposed wires have reacted to winter moisture and salts by turning blue and powdery. Terminal ends have corroded, rusted or just plain evaporated away. Aged wires not only keep an engin ... [Read Article]
Latest Ad: Looking for a John Deere 50, 520 or 530 in good shape and preferably with power steering and three point. May be interested in a 620 or 630. Thank you. [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
