Limbhangers
In my 5200 I have the old style steering I believe it is commonly referred to as a Saginaw system. Does anyone know if the steering motor (valve under the steering wheel) is the same used in the Oliver tractors such as an 1850?
My box seems fine for now, the column is my only real problem it is all loose and I can't get it tight for some reason.... I was going to hunt down up a replacement to keep as a reserve and I noticed an Oliver unit at the local salvage yard which looked like it was identical. I don't know that though. I think the Oliver unit came from an 1850.
