I've decided I want at least one tractor with functioning gauges. So, I ordered a set off of this site to install on my 740. The new sensor went in no problem, but it doesn't seem
like it is sealing properly. The center sensor is loose enough that it can be wiggled slightly and a little antifreeze will seep out. I'm not sure I can get the 5/8 inch fitting any
tighter, I'm worried it will strip out if I try to turn it any more.
Any suggestions would be helpful.
