Company Logo Shop Now
Order Ford 4000 Parts Online
Ford 4000 transmission questions/ pto
mikewood869
02-04-2019 09:33:28
Does anyone know if the 3 cylinder 4000 could have come with live pto? I’ve been looking at 8 speed transmission with live pto. I was told that the clutch is 2 stage but the pto lever is in a different spot, like on a 3000 with live pto.
The picture is of a 3000 rear end with live pto, that’s what the one I’m looking at looks like. I guess it was a state tractor that I’m looking at.
mikewood869
02-04-2019 18:50:12
 Re: Ford 4000 transmission questions/ pto in reply to mikewood869, 02-04-2019 09:33:28
I think the first picture that I posted (rear end and transmission) has live pto (I see why you can’t swap the housings and axle parts to that rear end or the whole rear end onto the 3000 style 8 speed. From what it seems I also wouldn’t be able to swap the pto etc from the 3000 style rear end into the 4500 rear end). The second picture is of my 4500 rear end, which I’m guessing that there is enough parts in it to make the rear wheels move and the dif lock. I would like to make the 4500 into a ag tractor (pto and 3 pt) and have the backhoe and loader on (I’m guessing that the backhoe and load frame would fit). At least that’s the plan.
Sean in PA
02-04-2019 18:29:19
If it has live PTO instead of independent PTO, then it would have the 2000/3000 style piston hydraulic pump on the left side of the engine back near the flywheel. If it has the gear pump in the right side of the center housing then it should have independent PTO.
mikewood869
02-04-2019 16:28:02
Thanks I just wasn’t sure about that part swap, guess I got to keep looking.
Destroked 450
02-04-2019 14:49:53
Being a state tractor it's most likely a 4110 which is a 3000 chassis with the larger 4000 engine.
4500 axles will not work on a 3000 center section.
mikewood869
02-04-2019 12:24:18
I was wondering it you could swap the axles from the 4500 to that
mikewood869
02-04-2019 11:05:00
After relooking at the photos, would it be possible to swap the rear axles from a 4500 rear end and then attach them to the rear end of this one
Fordfarmer
02-04-2019 12:20:01
 Re: Ford 4000 transmission questions/ pto in reply to mikewood869, 02-04-2019 11:05:00
That's not a 4500 rear end in your picture... it has drum brakes. Likely a 3400. 4000's and 4500's would both have a double reduction rear end with wet disk brakes.
Fordfarmer
02-04-2019 11:00:41
Very uncommon, but it was an option.
Latest Ad: need 3 point arms (with the ball) especially need the [More Ads]
Copyright © 1997-2021 Yesterday's Tractor Co.
