1710 remotes
sllimec47
Has anyone tried the HV 4020 kit? Does it bolt right on where the plate goes near the quadrant control? or does it require an adaptor plate? Any in sight would be greatly appreciated.
If you asking about adding the valve block, it bolts right in
Between the tractor and the cover, mine is the red block between the blue, then the outlets bolt to the back of the tractor, my tractor is a 1720, so it may be close to the same on yours.
