Hello, I wrote on here a month ago about my dual
power problems on a 7710 dual power Well we
went through the dual power and the disks were all
fried. So we put all new disks and floaters in for the
low side. The High side looked ok but we changed
them while we were in there along with all the dual
power orings seals. Got it all back together today
and it moved about 50 feet then quite. It like wants
to move but won?t when I shift the dual power I feel
it shift but still won?t move
I installed a t fitting on line going to dual power and
with it running it only making 25 psi. When I shift
dual power it don?t change. When I turn pto on it
drops then slowly works it?s way back to the 25 psi
the pto also starts super slow and if u hold a 2x4
against the pto when You turn it on you can stop it
from turning.
Is there a way to tell if it?s the pump bad or
somewhere else leaking? I was told it should have
150-200psi Can I just eliminate the pto? It?s a
boom mower so the pto is never used. The boom
hydaulics uses one scv outlet and they work fine.
Thank you
from turning.
Thank you
