New Clutch Pressure plate bearings 1974 4000 and Don't work
Jcosta1369
New User
[color=black:691d1fa661][/color:691d1fa661] :cry:Had a rusted leaking freeze plug in the back of the Motor behind the Fly wheel. While I had the tractor split I went ahead and replaced the clutch,Pressure plate, throw out bearing and Pilot bearing. also put a new crank seal on the back end. After putting it all back together went to drive the tractor and nothing happened. the clutch feels like its engaging and disengaging but the drive gears on the transmission are not turning. What did I do wrong?its a 1974 4000 and has the 11" Plate and 29 spline clutch (double clutch)...Very sad in Alabama.. Help Please. Can I take the steering wheel plate that mounts to the top of the Bell housing off and inspect the operation that way
