BarnabyHooge
Finally got good spark at the coil on my 860, but still getting random and intermittent spark at the plugs. New Cap & rotor, and I checked all the plug wires for continuity and resistance.
The tractor will start for 10-20 seconds and stumble through a bit then cut out. Is it possible the distributor shaft is slipping somehow? Seems fine with the cap off.
I'm not a loss and what would be causing it. The rotor doesn't have the metal clip but it is very snug on the shaft.
Anything else I should check?
