Hello,
I am wondering exactly what the manual means wheb it says tighten the nut (#7 in exploded view) until no slack. Is this referring to the gap between the spring washer and the bearings (#9) ? is there to be some movement by backing of a 1/6th of a turn? Is the total movement of the shaft only 3/32 including the spool valve movement?
Thank you
Thank you
