I am assembling an 401T TW 25 engine to put it back into a ford 8700.
In the package with the front crankshaft seal were these parts on the bottom of the photo.
Does anyone know what they are for?
I think the long black pieces are for the rear seal if I didn't have the later style bolt on seal retainer which I do.
I also have a large plastic washer ( not pictured) that appears to go in the timing cover ahead of the front seal.
I haven't investigated but I think the smaller o-ring may be for the oil pump but I'm not sure.
I'm lost on the other stuff especially the large O-ring.
It appears the metal washer goes against the crank gear then the spacer goes on, but there wasn't any sealant of the spacer when I removed it??
Thanks
Thanks
