Ford 3000 no longer runnning
melhath
New User
Hi My ford 3000 was working fine up until 2 days ago when I parked it up and stopped the engine. I know at the time the fuel was getting low but as far as I knew it had not run out, however, when I went to restart it (about ten mins later) it would not go. I filled it up with diesel and still could not get it to run. After bleeding the injector pipes for quite some time I finally got it running again but when I stopped it again having finished with it the dam thing would not start again. I have tried bleeding the system again and seem to be getting some fuel out of 2 of the injectors but hardly any out of the middle one. To be fair there does not seem to be a lot of derv coming out of the two that are kind of working. There is fuel at the pump bleed bolt but not really coming into the injector pipes. Any help would greatly be appreciated please.
It only has one filter and when I opened up the bleed bolt fuel came straight out. I have loads on fuel at the pump bleed bolt too.
