7710 fwa axle options
edhOH
Late model 7710 II series. Trying to find front seals. Parts place having trouble finding what I need. One seal is approx 7 7/8 od. Only markings I could find on axle housing were 18738 on left side and 342 on right side. Embossed ?cic? (?) also on one side. They can?t seem to find the seals and bushings I need. Any help is much appreciated.
Large seal says carroro
Hate to say it but check with a local JD dealer, they used the some brand of front axles on some of their tractors.
A poster a while back said he get the parts he needed at JD cheaper.
This should be what you need for the seals. I gotta believe that NH still sells them.
I don't think you'll find much help with the JD guys. To the best of my knowledge, they never used the Carraro axles. I always went to JD for my ZF axle parts needs, where there was some interchange.
Seals
After another hour of searching they finally found the ones I needed. Had the seals in stock, but not the bushing or king pin shims. Once this gets put back together should be good as new. Thx for the replies.
